stp complete fuel cleaner??
Old Nov 18, 2008 | 08:45 AM
utter02's Avatar
Default stp complete fuel cleaner??
ok ive herd good and bad things about fuel cleaners....any1 got an opinion?
Old Nov 18, 2008 | 01:33 PM
P_Adams's Avatar
I have never used one.
I have (however) used Dry Gas (Methel Alcohol) once or twice during the winter.
If you've got an injector which needs cleaning, you'll need something stronger than what could be put in your tank!
P
Old Nov 19, 2008 | 04:38 AM
teefunk01's Avatar
Not sure if this stuff works but I would never use them on my 1000cc injectors or my fuel pump
Guess I am just paranoid but I dont trust stuff like that
Old Nov 19, 2008 | 08:28 AM
ram0869's Avatar
dont know bout stp. but i have used lucas fuel additive, never had a problem with them, car feels smoother. last used it back in july....
Old Nov 19, 2008 | 09:38 AM
P_Adams's Avatar
The only products I've ever put in the engine (other than Motor Oil, Antifreeze etc) has been Marvel Mystery Oil (Top Cylinder Lube), GM Top Engine Cleaner (De-carboning Agent), Rislone (Sludge removing Agent) and Dry Gas.
Depending where you live (and the winter's you experience), you might want to stash a can of WD40 in your emergency supplies tote. Not only will it lube a s**t load of things, but it will also dry off wet ignition wires (displace any moisture) and temporarily allow the engine to start (which previously wouldn't).
P
TurboedGSR
Aug 6, 2008 12:57 PM
EK45VTi
10
Sep 21, 2004 07:03 PM
brownman72000
Nov 10, 2002 09:17 AM
vtecdc2
Aug 5, 2002 10:56 PM
Q-OnE
Aug 5, 2002 11:38 AM
