HIDs in 94 OEM fogs??
You'll most likely melt the housings.
Although HID's draw less watts (from the car's electrical system) the bulbs (emitters) do run hotter. That's why you often see warranty disclaimers on aftermarket projector lamps with regards to HID usage.
P
P
thanks for the input. The lense is glass and the housing on them is metal tho so idk if they will melt from the HIDs. i dont think i can put HIDs in these fog lights anyway. its all sealed and got to take everything apart to get to the bulbs. well i guess i got a HID kit for sale now
are the 96-97 fogs like the 94-95 fogs? i konw they mount diff and everything. but is the bulb and everything inside the housing? it looks like you have to take the whole thing apart to do it
I'd assume they're all the same basic build. Remove them from the bumper and then turn them on the bottom - should be 3 small phillips screws. Undo those and you can get access to the bulbs and the wiring.
For the wiring it's a rubber grommet. You should be good. When I get my kit I'll see if I can take pictures.
Yeah thats what i tought. but i wanted to see if anyone else has does it because the screws are rusted in and cant get them out. so im prolly going to have to drill them out and put new ones in. sucks but gotta do what gotta do i guess
yeah i got one that fit perfect and used alot of PB blaster and it still ended up striping. the metal is rusted and too soft. so im just going to have to get new screws. i wish i could have just got these out. i got two screws out of one and one screw out of the other. others are stuck.
ok well for those of you wanting to see how i did my HIDs in my fogs here is the link https://honda-tech.com/forums/showth...&highlight=hid
Got a source to back that up about the HID capsules running hotter than halogen? I'm pretty sure they do in fact run cooler than 55W halogen bulbs. My headlight housings don't get nearly as hot w/ my HID retrofit as they did w/ stock 55W 9006 bulbs.
Like Patrick just stated.
These bulbs do run hot, but they don't melt metal.
You can fire up an HID projector for hours, and yet you can hold the projector without burning yourself.
Nvious R
Jan 22, 2004 07:36 PM
