do i need a TOP HAT for coilovers
Old Nov 18, 2008 | 12:19 AM
taimysho0's Avatar
Default do i need a TOP HAT for coilovers
hey im deciidng to buy some ground controls and tokico illuminas for my 00 em1. what is a top hat and do i need it to have this installed? if im correct, this is one of the best setups for my civic right? i dont plan on aut-x, just dumped and DD.
THANKS!
Old Nov 18, 2008 | 05:57 AM
jsant07's Avatar
a tophat is what sits on top of the shock and spring assembly and mounts to your car so yes they are necessary, although you can reuse your stock ones it would mean taking the stock suspension apart which you need the proper tools for otherwise you could hurt yourself...but you can usually borrow a spring compressor from autozone. but your best option is to go with new extended top hats because theyll allow you to go lower without sacrificing suspension travel which will make the ride alot better. you can find them on ground controls website
mattyv's Avatar
you can just use yur stock top hats
Old Nov 18, 2008 | 06:32 AM
ej1serge's Avatar
you CAN use oem tophats but its recommended that u use longer ones so they pull the strut shaft out so u dont bottom out and blow ur strut if ur gonna be dumped.
Old Nov 18, 2008 | 06:42 AM
dividedas1's Avatar
makes the world of a difference, trust me :-)
Old Nov 18, 2008 | 08:50 AM
H22Ej1's Avatar
Shenanigans
extended top hats = baller status
on my ef i have konis + omni coilovers dumped the extended top hats make all the difference in the rear, i dont have them on the fronts and my struts bottom out over every little bump
Old Nov 18, 2008 | 09:01 AM
Fatchance187's Avatar
yeah I blew a rear strut when I first got my yellow definetely go for the extended top hats unless you go for the race valved konis
YipMan_Style
Suspension & Brakes
Jun 29, 2007 05:45 PM
craphatch
Feb 24, 2007 03:57 PM
streetspeed607
Apr 17, 2004 11:31 PM
LudeAchris2001
Aug 13, 2003 06:41 AM
FastAndFatalLude
Mar 23, 2003 09:50 PM
