Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Tire PSI question....
Old Jul 31, 2002 | 01:44 PM
Madracer1's Avatar
Default Tire PSI question....
I was wondering how safe is it to run on more PSI than the max rated on the wall of the tires that i have. I got less run off on 47psi(btw Potenza RE730's with max of 44psi) but I dont want to go higher than that....Or maybe I have alignment issues- maybe camber??? Please let me know what do you think....
Thanks in advance!!
Rado
Old Jul 31, 2002 | 01:58 PM
Kamin's Avatar
Default Re: Tire PSI question.... (Madracer1)
why?
the max psi is what its safe for on the street
now if your autoxing or somthing, then you can go higher
but i wouldnt run higher than 35 on the street.
Old Jul 31, 2002 | 03:12 PM
Doctor CorteZ's Avatar
I wont even get into how many things in that post dont make sense
but why you would want to LOSE grip by OVERinflating your tires is beyond me
run 36-38 MAX on the street
Old Jul 31, 2002 | 03:25 PM
Madracer1's Avatar
Default Re: Tire PSI question.... (Doctor CorteZ)
First off, SORRY FOR THE CONFUSION--I AM TALKING ABOUT AUTO-X.
Ok, the porblem I am experiencing is that the outside edge of the tires gets eaten up way more than the middle or the inside og them so that was the reason that I was putting more pressure in them. Now, I am not really sure that I have a problem with camber......
Old Jul 31, 2002 | 07:31 PM
are the tires rolling over ?
have you chaulked the side of the tire to set your pressure?
Old Jul 31, 2002 | 08:33 PM
Madracer1's Avatar
Yes the tires do roll over about half of an inch of the little triangle limiter on the tire itself. Yea I have chalked but I reached 47psi hot like I mentioned above and that is 4psi more then the max limit for the tire so I was wondering how safe is to do that???
Thanx again!!
Rado
[Modified by Madracer1, 9:34 PM 7/31/2002]
Old Aug 1, 2002 | 03:53 AM
Mista Bone's Avatar
D Tranny Guru
the sidewall pressures are for COLD readings.
Imagine a BFG R1 going out cold at 30 psi, coming in HOT at 55-60 psi.
Escort Endurance Series and a C4 Corvette.
Driven by Bill Brauswick.
kenji51590
Jan 7, 2012 09:13 PM
AznMTboy
Aug 26, 2005 06:25 AM
jerry5150
May 10, 2004 06:14 PM
Blazin Si
19
Jan 15, 2004 06:11 PM
Aaron M
Nov 25, 2002 04:47 PM
