Best (cheaper) alternative to stock OEM dampers
Old Nov 17, 2008 | 08:50 PM
Outrun's Avatar
Default Best (cheaper) alternative to stock OEM dampers
The new board still has teething troubles so I'm unable to search due to an invalid security token (whatever that means).
Anyways, do you experts have recommendations for an aftermarket damper that has similar damping characteristics to the OEM ITR dampers? The OEM ITR dampers are in the $230 range. I'm looking for something cheaper but just as good. Otherwise I'll just have to save up for the OEM dampers.
Old Nov 17, 2008 | 09:23 PM
BoS_DC2's Avatar
Well, I have a set of Tokico Illuminas on my 97R right now on the 3rd setting out of 5 total settings and it feels very much like the stock dampers, better. Don't know how long it'll last though.
Tokico Illumina
5 way dampening adjustability
Old Nov 18, 2008 | 04:48 AM
jimmypol's Avatar
I did some research in the old forum a couple of weeks ago, I wanted to know about good dampers for stock ride height, and it pretty much came down to a concensus on Bilstein Sports. According to my findings they will feel similar in comfort and will add performance over stock.
Good luck.
Old Nov 18, 2008 | 07:30 AM
vinuneuro's Avatar
$230 is 15% above list price.
$161.68- front
$163.38- rear
@ acuraoemparts.com
If you're using stock springs, nothing is going to out-perform stock, valving wise.
Old Nov 18, 2008 | 12:33 PM
nsxtasy's Avatar
H-T Order of Merit
Yup. That's what I put on my ITR when the stock ones started to go.
You can look up Bilstein dealers on the Bilstein website. Here are the part numbers for the Bilstein Sports for the ITR:
ACURA INTEGRA SP FRONT 96-01
Manufacturer: BILSTEIN
New part#: F4-BE5-2340-H0
List Price: $ 202.00
Setting: Sport (SP)
Position: Front
ACURA INTEGRA REAR SP 96-01
New part#: F4-BE5-2341-H0
Setting: Sport (SP)
Position: Rear
I don't know whether or by how much you might get them at a discount.
It's also worth noting that most aftermarket shocks (including Bilstein, Koni, Tokico, etc) come with a lifetime warranty to the original purchaser, which is an advantage over the stock ones. Save your purchase receipt!
Old Nov 18, 2008 | 12:49 PM
irev210's Avatar
best alternative to stock oem dampers?
used oem dampers...
Old Nov 18, 2008 | 01:33 PM
Todd00's Avatar
I said I don't want a title!
Just get Koni Yellows and call it a day. You can also set them on the lower perch and lower the car a few mm.
lsubluelude
Acura TSX
Jan 9, 2019 04:38 PM
fuzzysig
Engine Management and Tuning
Oct 23, 2016 11:29 AM
BlueStar
Dec 25, 2007 02:39 PM
VertZ24
Northeast (Sales)
Nov 6, 2007 10:45 PM
jolt-tsp
Suspension & Brakes
Sep 6, 2005 05:34 AM
