wrong w/ oil pressure sending unit out of the tee from the block?
Old Jul 31, 2002 | 01:28 PM
ceemarun's Avatar
Default wrong w/ oil pressure sending unit out of the tee from the block?
i just heard that its really bad to have the oil pressure sending unit just coming off the tee for the oil feed. whats wrong with that, and where else can i tee it off?
Old Jul 31, 2002 | 01:35 PM
EE_Chris's Avatar
Default Re: wrong w/ oil pressure sending unit out of the tee from the block? (ceemarun)
The problem is the weight that is now hanging off the stock oil pressure location. People sometimes elect to run a line from the stock location to a T that is mounted on the firewall.
Here is a link to the EnDyn site detailing this: The Link
Old Jul 31, 2002 | 06:38 PM
M.A.R.C.'s Avatar
Default Re: wrong w/ oil pressure sending unit out of the tee from the block? (EE_Chris)
thanks I wanted more info on this... I need to buy my oil feed lines soon
Old Jul 31, 2002 | 08:14 PM
B20-T's Avatar
Default Re: wrong w/ oil pressure sending unit out of the tee from the block? (CivicRyda2k)
just get the steel t instead of the brass..i am running the steel T and it is holding up fine..i had it on for about 6months now..no problems..
Old Jul 31, 2002 | 08:29 PM
ion_four's Avatar
Default Re: wrong w/ oil pressure sending unit out of the tee from the block? (B20TURB0)
I'd really suggest running a line off the block and having the senders, T and whatnot hanging off something else as support. The chances are slim that it'll break, but you really don't want to lose oil pressure and have a fitting broken off into your block!
98civicEX's Avatar
main reason is that when you have the weight of the T on the block, w/ all the vibration...it could snap off, hence causing a BIG job to retap the block from that position....
Old Jul 31, 2002 | 08:32 PM
Accord94DX's Avatar
Default Re: wrong w/ oil pressure sending unit out of the tee from the block? (98civicEX)
that link is just what i was looking for...thanks
Old Jul 31, 2002 | 09:30 PM
Pengo's Avatar
Default Re: wrong w/ oil pressure sending unit out of the tee from the block? (Accord94DX)
ok, that pic at the link is almost exactly how i have my oil press gauge set up currently, but when i choose to go turbo and replace the T with either a 4 way, or just get rid of the stock oil pressure sensor and use that for the oil feed line, will the 1/8 nylon tubing provide enough flow for the oil feed line? i kno most pple would suggest upgrading to someone else like stainless steel braided, but i just wanna know if the 1/8 tubing will flow enough for the oil feed. thanks
-alan
Old Aug 1, 2002 | 07:47 AM
Smashback's Avatar
Default Re: wrong w/ oil pressure sending unit out of the tee from the block? (Pengo)
Yes 1/8 will be enough because it's very high pressure...and it's not the fitting they are worried about cracking it's the block.
[Modified by mplex2000, 5:02 PM 8/1/2002]
Old Aug 1, 2002 | 08:55 AM
downpipe's Avatar
my steel tee wound up leaking eventually, keep an eye on it.
B18EG6
Mar 25, 2012 06:20 AM
totsie7944
May 1, 2008 04:52 AM
97CWITR
Feb 22, 2007 08:36 PM
integra-modder
Jul 7, 2004 08:19 AM
Acura_I-RS
Mar 16, 2003 04:45 PM
