Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Replacing Brake Pads on a 06 Civic LX
Old Nov 16, 2008 | 11:02 PM
smxcan's Avatar
Icon2 Replacing Brake Pads on a 06 Civic LX
Has anyone come across a site that has good steps (preferably with pictures or videos) to replace front brake pads specifically on the 06 Civic LX?
From what I’ve read/seen on Google, it looks like a simple DIY job.
But before I start, I though I’d get some feedback from techs that have already done this.
Any recommendations on a good brand of brake pads?
Any problems I should be prepared for on the 06 Civic?
Assuming the rotors are fine, aside from the pads, tools, and grease, is there anything else needed?
Old Nov 17, 2008 | 11:57 PM
pd0019's Avatar
hawk HPS or HP+ w/ ate blue brake fluid and ss lines
no problems
jack, jack stands
i'm assuming you are doing fronts only and not your rear drum setup. drums are a lot trickier. if it is your fronts, it is a very easy job. unlike w/ older model hondas though, there is a ring that you need to hold in place as you take the bolt that holds the caliper together. 19mm crescent wrench i believe is what you need.
Old Nov 18, 2008 | 06:08 AM
pgpbubble's Avatar
Use factory pads please. Theyre only around $40-50 and are the best $ can buy.
rjmq06
20
Oct 22, 2009 11:58 AM
tz12789
Nov 10, 2008 09:43 AM
stripes777
Mar 2, 2007 08:38 PM
ndogg810
Honda Civic (2001 - 2005)
Jan 6, 2007 05:23 PM
BD7581
Dec 13, 2003 08:09 PM
