NEED HELP!!! with an accord SOHC VTEC ecu
Old Nov 16, 2008 | 05:22 PM
true-elements's Avatar
Default NEED HELP!!! with an accord SOHC VTEC ecu
i'm doing a SOHC VTECH in a 92 accord 5sp does anybody know what ecu i should use in my swap......
Old Nov 17, 2008 | 04:20 AM
my240sx4u's Avatar
what obd?
Old Nov 17, 2008 | 11:14 PM
momstaxi's Avatar
use a poa, a 94-95 accord ex ecu, or you could use a p28
you will need to change some pins in your ecu plugs though if you use the poa
Old Nov 18, 2008 | 12:52 AM
jwicecold's Avatar
I would use 94-95 accord EX ecu.. Same engine thats in that car is what your tryin to put in your 92 accord. Just stay with the stuff that is plug N play.
bseriescrxsi
Sep 21, 2009 01:34 AM
CRX-RX
Feb 2, 2003 06:21 PM
smokin rubber
Dec 21, 2002 11:54 AM
