Black box next to cam gears???
Old Jul 31, 2002 | 12:29 PM
Lowez's Avatar
Default Black box next to cam gears???
Does anyone know what this box is? Its beside my cam gears on my b18c 92 hatch. It has a black plastic cover on it with a couple of wires coming out of it.. It some lettering on it saying p28... Is this something to do with my ecu?? Thanks for any adivce...
Old Jul 31, 2002 | 12:37 PM
badCRX's Avatar
New User
Default Re: Black box next to cam gears??? (Lowez)
I think you are referring to the cruise control box. Does it have a cable going to it from where your accelerator pedal is?
Spade's Avatar
Could be VTEC solenoid.
EDIT: Spade has lost his mind.
[Modified by Spade, 1:38 PM 7/31/2002]
Old Jul 31, 2002 | 12:41 PM
Lowez's Avatar
Ya there is a hard cable coming out of the box. There is also a connector on it that you can connect and disconnect. I have a jdm type R wheel so if this has anything to do with the power steering then can I take it ou???
Spade's Avatar
Can you see it in here?
Old Jul 31, 2002 | 12:42 PM
Lowez's Avatar
Sorry I mean cruise control, not power steering...Silly!
Old Jul 31, 2002 | 12:44 PM
Lowez's Avatar
No I don't see it.. I did have the cruise control option in my car though....
Old Jul 31, 2002 | 12:46 PM
Spade's Avatar
It would be right by the motor mount. and have vaccum lines running to the intake manifold and a hard cable line running into the fire wall to the gas pedal. If so, you can remove it.
Old Jul 31, 2002 | 12:49 PM
Lowez's Avatar
Ya the cable does go into my firewall. And it's bolted right next to my engine mount... SO I guess this is the cruise box.. Time to take it out.. Thanks!
Old Jul 31, 2002 | 12:51 PM
Spade's Avatar
Have fun with the wire going through the wall.
Be sure to disconnect from the gas pedal.
*got irritated and used cutters*
iwantspeed
May 24, 2008 07:14 AM
CMO
Apr 20, 2008 08:17 PM
AlxSiR7
Mar 17, 2005 05:24 PM
accord2nv
Oct 13, 2004 09:16 PM
PSU
Jul 24, 2003 12:25 PM
