engine lose power after 3000 rpm, need some help
Old Nov 16, 2008 | 04:47 PM
mr. goodwrench's Avatar
Default engine lose power after 3000 rpm, need some help
have a 93 civic hatch, just droped in a b18b in there. started the engine and it started fine/idle fine also. but when the engine revs up to 3-3500 rpm the engine loses its power. as if the gas gets cut off or someting. if i was to let go of the pedal the engine will drop down to idle and stays on but if i keep the load on the gas pedal the engine dies. i dont have any cel, and i never came across something like this before.
if i can get any suggestion on how i can fix this it'll be great. thanks
Old Nov 16, 2008 | 04:51 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: engine lose power after 3000 rpm, need some help (mr. goodwrench)
TPS and MAP connectors switched around? Timing correct? Just a thought...
Old Nov 17, 2008 | 04:35 AM
SOHCpoorguy's Avatar
I had the same problem with my stock P06 whenever it rained, turned out to be the ECU, try a different one
ekcivic2
Jan 27, 2020 08:10 PM
dh1212
Apr 2, 2016 04:08 AM
globy123
Jun 15, 2007 12:45 PM
Batoutahell
May 7, 2003 04:26 AM
