Temerature gaugue
Old Nov 16, 2008 | 03:38 PM
deerman2701's Avatar
Default Temerature gaugue
So my temperture gauge in my 99 civic lx just shoots up to hot things ive tryed is filling the radiator resovior changing the fan switch the thermostat and the temperture sender still no go my fluids are good and i dunno what else i also checked the fuses what else can this be a faulty gauge cluster or what
Old Nov 16, 2008 | 03:55 PM
96-EJ6 B18C's Avatar
Default Re: Temerature gaugue (deerman2701)
Does it go to full hot as soon as you turn the key to the "ON" position without starting the engine???
Default Re: Temerature gaugue (96-EJ6 B18C)
Yes it does right away.
Old Nov 16, 2008 | 04:09 PM
The single wire temp sensor that threads in to the head below the distributor may be faulty, OR the wire that connects it to the gauge cluster may have a short to ground. Either of those could cause that indication. Try pluging another sensor in to your harness and touch it to the engine (this sensor must be touched to the engine to work because the engine is it's ground), have a friend sit in the car and turn the key on and watch the temp gauge. If the gauge still pegs you have a short some where between the sesnor and the cluster or the cluster itself is bad. To eliminate the wiring, hard wire the sensor to the back of the cluster.
njw202
May 5, 2012 06:44 AM
zippakilla
Feb 21, 2009 11:02 AM
o0ohaviko0o
Apr 1, 2008 07:04 AM
Ryanman
Feb 10, 2008 11:51 AM
Rhetoric
Sep 14, 2001 06:55 PM
