15x7 with 35 offset on crx?
Old Nov 16, 2008 | 10:49 AM
90crxdxY8's Avatar
Default 15x7 with 35 offset on crx?
Hey all this is my first post here and im in need of help asap..
I have a opportunity to buy a set of borbet type C's they are 15x7 and a 35 offset and 195 60 15 rubbers.. my cars lowered on a pro kit springs will this setup rub or should i be OK? im possibly going to get them tonight
Old Nov 16, 2008 | 12:01 PM
blaak-crx's Avatar
Default Re: 15x7 with 35 offset on crx? (90crxdxY8)
I have mags 15x7 offset 35 with 205 and it doesn't rub with rolled rear fenders. So in your case, it may not rub or barely. Also depends what tires you are using.
Old Nov 16, 2008 | 12:09 PM
90crxdxY8's Avatar
Default Re: 15x7 with 35 offset on crx? (blaak-crx)
its gunna be a 195 60 tire not that tall or wide im gunna go get these if they wont rub
Old Nov 19, 2008 | 11:07 PM
bnorth's Avatar
Should be fine.
Old Nov 20, 2008 | 12:38 PM
nsxtasy's Avatar
H-T Order of Merit
The tires are MUCH too big for your car and they will probably rub. You need 195/50-15.
Old Nov 20, 2008 | 12:41 PM
nsxtasy's Avatar
H-T Order of Merit
No, you can't jump to that conclusion. Your 205 tires are probably 205/50-15, which are less than 2 percent larger in diameter than your stock size. Because his tires have a higher aspect ratio - 195/60-15 - they have a much taller sidewall than yours, so they wind up almost 7 percent larger in diameter than stock. They will probably rub, even though yours don't.
RanCRX
Oct 2, 2014 08:53 AM
2000EJ8
Suspension & Brakes
Mar 17, 2009 10:42 AM
1994delsolLS
17
Jan 30, 2009 03:18 PM
SpeedingHatch
Mar 10, 2006 06:48 AM
jingjing
Jan 17, 2003 01:19 PM
