Idle Issue
Old Nov 16, 2008 | 10:29 AM
Jakester9500's Avatar
Default Idle Issue
So I was having an erratic idle, so i did some work to my car.
I took off the intake manifold, to replace the intake manifold gasket. Replaced the throttle body gasket, bought a new tps and put that on. Turned the screw down on the FITV, cleaned out the IACV and cleaned the throttle body and intake manifold, then reassembled.
So I no longer have an erratic idle, but I have a steady idle at about 1500 rpms, with the idle screw turned the whole way in. I've sprayed starter fluid around, and it seems to have no affect on things.
I am throwing a CEL and I couldn't get it read because I am running a obd1 ecu in an obd2 car.
It's a 97 civic, with a y8 and a z6 manifold.
THanks for any insight on this high idle.
Old Nov 16, 2008 | 11:19 AM
96-EJ6 B18C's Avatar
Default Re: Idle Issue (Jakester9500)
Why can't you read the CEL??? All you have to do is jumper the 2-pin connector just like an OBDI car. Check out this link on how to do it...
https://honda-tech.com/zerothread/1901557
Old Nov 16, 2008 | 11:34 AM
ahh, i forgot that you can do that since i never have done it. but i'm going to give it a shot, thanks!
Old Nov 16, 2008 | 11:38 AM
Junior Tech's Avatar
Default Re: (Jakester9500)
did you set the tps with a ohms meter?
Old Nov 16, 2008 | 11:42 AM
nope, i just screwed it on.
Hmm, looks like codes for MAP sensor and TPS.
I don't know why i'd be getting one for MAP after that, I didn't touch it
Old Nov 16, 2008 | 11:45 AM
Check and make sure you have the connectors plugged in to the correct sensor (they can be reversed) TPS will have a RED center wire.
Old Nov 16, 2008 | 02:30 PM
yea, i did try to reverse them, and the car ran like dog ****.
norcalB18
Dec 7, 2015 10:24 AM
michaelsej1
18
Feb 21, 2011 07:13 AM
Gho$t
Nov 10, 2009 10:26 PM
ctr status
Mar 2, 2009 08:11 PM
AlxSiR7
Feb 1, 2005 11:42 AM
