Car wont start unless its jump started!!
Old Nov 16, 2008 | 01:27 AM
91b16acrx's Avatar
Default Car wont start unless its jump started!!
OK well, my car has been having problems starting up these past few months. I would have to turn the key several times and it would start. Now when I turn the key, all I hear is a click and the motor doesnt crank. The car only starts unless it gets jump started. It starts 100% if the time when it gets jumped. It kinda annoying jump starting your car everyday I drive a 98 Gsr btw, motor is stock with about 120k milage. Any ideas?
Modified by 91b16acrx at 2:33 AM 11/16/2008
Old Nov 16, 2008 | 02:13 AM
pkdog167's Avatar
Default Re: Car wont start unless its jump started!! (91b16acrx)
Your battery must be dying
Old Nov 16, 2008 | 02:40 AM
halocore's Avatar
Default Re: Car wont start unless its jump started!! (pkdog167)
get a new battery, or check to make sure your alternator is going bad and is not draining your battery, by the way you can always push start your car if you ever get stranded and there's no one to jump your car.
i ran into many situations where i would be stranded becuz there wasn't anyone to jump me, but luckily my car is manual.
Old Nov 16, 2008 | 06:41 AM
dudeomega2000's Avatar
Also, it is either your battery or alternater. Take your battery to an advance auto parts or autozone and c if the batt is good. If the batt is good it is 99.9% chance your alternator is gone. The other thing that could be happening is check when you turn on your key (not cranking the car but just in the on positoin) that your battery light comes on in your cluster. If the light does not come on it is a fuse in your fusebox that is gone.
NiKKa NiKKy
Jun 30, 2022 09:59 PM
rovertnamrod
Honda Civic (2001 - 2005)
12
Jul 17, 2013 06:25 PM
lawlss
15
Sep 14, 2009 10:23 PM
blkDOHCsol
May 9, 2007 05:37 AM
Legendaryyaj
Mar 8, 2007 01:41 PM
