How high do you guys launch ALL MOTOR?
I went to the track today and made about 5 or 6 passes experimenting with different launch RPM's. I used my 2 step launching between 7400 to 7900 RPM and was not able to cut anything better than a 1.8 60 ft. and the car was bogging off the line everytime. I did not want to try launching any higher because I was worried about breaking an axel and not being able to make the 100+ mile trek home. My fuel cut is at about 9300 or so. Any suggestions on how to cut my 60 fts? I'll try launching higher next time if I have to and bring some spare axels.
Here's some info about my setup:
'01 ITR chassis
B18C w/ JDM 4.78 tranny
221whp/143wtq
23" MH slicks on 13" Lenzos
So does anyone launch any higher than 8000 RPM and how are your axels holding up?
Modified by HotboxedTypeR at 4:59 AM 11/16/2008
'01 ITR chassis
221whp/143wtq
your launch seems about right, but what else do you have. to improve your 60 feet u might consider getting traction bars.... just a suggestion.
It's all about the pre-loading of your suspension to relieve the stress on drivetrain parts.
If you don't want to raise the rev limiter any higher and it keeps bogging maybe try raising the tire pressure a little bit more. Every car/setup is different so you can't always go off of what everyone else does, just simply use it as guidelines. Pre-loading the suspension should also help
with our itr we launch at 8600 shift at 9500 on 23's. Psi is 8-8.5, On 22's we launch at 7800. Stock itr axles Holding up fine. What did you hit? This is the black itr from DNR right?
Originally Posted by JDCIVIC
LoL!!! pete? dis is joel! so u went to sac race & tune wthoout telling me?
