help with transmission swap in DA
Old Nov 15, 2008 | 08:19 PM
redDAinteg's Avatar
Default help with transmission swap in DA
I swapped a 98 civic type R s4c transmission into my 92 DA and I am using the innovative mounts and cable to hydro, but the problem I am having is with the rear mount bracket. I was trying to use the stock mount bracket which lined up no problem, but the bolts from my stock DA (17mm)are smaller than the hole on this hydro tranny. My buddy told me that I need a bracket that that will take the bigger 19mm bolts.
My question is do all 1994 and up integras have the rear bracket with the bigger holes for the bigger bolts ? And will that rear bracket fit a DA ? Anyone with a DA please let me know what you did when you swapped a newer hydro tranny, I need to figure this out quick to get my car running!
Please help, thanks.
Old Nov 15, 2008 | 09:25 PM
majinsoftware's Avatar
Most people I know that have just swaped the hydro parts into a YS1 casing.
Couldnt you just drill the holes bigger on the stock DA rear mount bracket?
Old Nov 15, 2008 | 09:54 PM
redDAinteg's Avatar
Default Re: (majinsoftware)
I will actually try to do that.
iluvmyef9
Apr 3, 2008 12:32 PM
91slamedrex
10
Sep 20, 2006 03:07 PM
clemsonteg
Jan 22, 2006 06:22 PM
gambo117
Mar 6, 2004 06:32 PM
vhd
Nov 9, 2001 05:10 AM
