squeaky clutch....????
Old Jul 31, 2002 | 11:11 AM
[HrZn]4life's Avatar
Default squeaky clutch....????
I was wondering if you guys could help me out with this... my clutch seems perfectly fine; it's grabbing solidly and gears go in smoothly....but when I press down on the clutch pedal it sqeaks louder than usual. You guys know what this could be?? Thanks
Old Jul 31, 2002 | 11:16 AM
Flux's Avatar
Default Re: squeaky clutch....???? ([HrZn]4life)
Mine is doing that EXACT same thing and it is getting louder.. I'm taking it in to the dealer on Friday to have it looked at under warranty...
Old Jul 31, 2002 | 11:17 AM
Reid's Avatar
Global Moderator
Take it to the dealer.
Old Jul 31, 2002 | 11:20 AM
Rory Breaker's Avatar
Take some WD40 or silicone spray and soak the rod and any moving parts you see on the clutch assembly under the dash.
Old Jul 31, 2002 | 11:21 AM
Default Re: squeaky clutch....???? (newgsrdriver)
so it's not mechanical but just needs lubrication??
Old Jul 31, 2002 | 11:58 AM
Junglist's Avatar
https://honda-tech.com/zerothread?id=179021
Old Jul 31, 2002 | 01:43 PM
Civic Minded's Avatar
Default Re: squeaky clutch....???? (Junglist)
That is a good post btw.
It actually does fix the problem temporarily, but is something that has to be repeated as the problem arrises. Kind of like a regular maintainence thing as the post implies.
Good Luck!!
hondaaccord94
Mar 6, 2006 03:45 PM
kshymkiw83
Acura TL, RL & ZDX
Jun 17, 2004 05:59 AM
