Widest wheel/tire without LTL steering issues?
Old Nov 15, 2008 | 03:08 PM
K2e2vin's Avatar
Default Widest wheel/tire without LTL steering issues?
Right now I'm running 14x6 with 195/60 tires, and would like to upgrade to 15x8 wheels with 225/50 tires to fit over 11" brakes. Really, I wanted 15x9's but looks like it's hard to find tires for 15's that wide. I'd like to know anyone else is running 8" wide wheels with 225/50 tires and if so, what rubbing issues do you have and do you have problems steering from lock to lock(as in not needing steering stops)?
Thanks, Kevin.
Old Nov 15, 2008 | 03:21 PM
hondacivic90zc's Avatar
Default Re: Widest wheel/tire without LTL steering issues? (K2e2vin)
Im running 16X7's with 205 tires and there isn't much clearance between the sidewalls up front and the knuckle (i can't really fit my fingertip between the two), but i don't know about 225's fitting
Old Nov 15, 2008 | 08:18 PM
A-to-the-J's Avatar
I'm looking to fit some 15x8 +15 all around. I'm thinking 205's will be good, anybody running something similar?
Old Nov 15, 2008 | 09:08 PM
K2e2vin's Avatar
Are you going for looks or maximum contact/squared shoulder? Reason why I'm thinking 225 is because those were the only tires that I found that were recommended for for 8" wide wheels. I couldn't find anything wider for 15's and 8" was pretty much the recommended max for that width tires. I'm pretty sure running a 205 would help but that would defeat the purpose of getting 8" wide wheels to begin with. If 205's work best, I'll probably get 7 or 7.5" wide wheels instead.
Old Nov 15, 2008 | 10:18 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
you can safely put 215 on a 7" wheel, i have seen 225's on a wider wheel, but you are risking rubbing on the strut. all this is with a stock backspacing.
Old Nov 16, 2008 | 01:48 AM
NlCK B's Avatar
there is only one place that i found info on fitting 225 on a ef and that here http://www.949racing.com/index...&ID=1
if u had any more questions i'd sugest giving them a call
Old Nov 16, 2008 | 02:27 AM
K2e2vin's Avatar
Default Re: (NlCK B)
Yeah I just saw that earlier. It says the /45 profile tires will fit but say nothing about the /50 profile(which are more common). I don't think they have much info on the 88-91 Civic/CRX's since they deal with mainly Miatas; I was hoping there was someone here who's running them could give me some feedback. Anyways, I'll still give them a call or shoot them an email.
Also, I don't mind having to roll the fenders but I'm more worried about the fronts because of the knuckles and the inner fender well.
Old Nov 16, 2008 | 11:36 AM
Default Re: (K2e2vin)
use a tyre diameter calculator to keep the overall diameter the same.
Old Nov 16, 2008 | 12:36 PM
http://www.handymanusa.com/articles/tire.html
45 profile on a 225 width tyre is about the same height as 50 profile on a 195 width tyre
bspeed
Jul 29, 2016 04:43 PM
mikeunreal2
Jun 3, 2007 12:12 PM
Mangotreemechanic
May 23, 2006 03:12 PM
Xymox007
Oct 13, 2004 07:39 AM
Muckman
Sep 28, 2001 06:15 AM
