Need a Mechanic or Shop recommendation, having tranny & clutch problems with my EF
Old Nov 15, 2008 | 01:46 PM
DC4 ENTHUSIAST's Avatar
Default Need a Mechanic or Shop recommendation, having tranny & clutch problems with my EF
I am having transmission and clutch problems with my d-series EF. I would like to replace the tranny with a fresh one, and put a new clutch in.
Does anyone know of a shop or mechanic that is inexpensive and does good basic work? I live close to SD, OC, LA.
Old Nov 15, 2008 | 02:08 PM
widebodyeg's Avatar
Default Re: Need a Mechanic or Shop recommendation, having tranny & clutch problems with my EF (DC4 ENTHUSIA
pm'ed
Old Nov 16, 2008 | 07:19 PM
Someone please help me fix this car... I just got laid off and need this car to run so I can look for a new job.
I would like to replace the clutch with a clutch kit and I am pretty sure the clutch pedal assembly needs to be swapped. I would also like to replace the clutch cable if its stretched and axle seals if their leaking. Hopefully this tranny is still in decent working condition.
I loosened the clutch cable a bunch and now the clutch pedal basically rests on the floor but does have a bit of tension when you push on it. It goes all the way down very sideways, you can kinda see what I am talking about in the photos below.
Pressed in
Released
Old Nov 16, 2008 | 08:05 PM
pandarex's Avatar
your pedal is probably broken, happens alot to ef's. your going to need another pedal set or to weld it up.
Old Nov 18, 2008 | 09:08 AM
DAb20vtec's Avatar
hit me up i got a shop i can swap the tranny and clutch for sure.
SpaceJamMartian
Mar 19, 2010 09:48 AM
kingcu90
25
Jun 18, 2009 09:35 PM
1990EFHATCH
42
Nov 21, 2008 09:30 PM
shhh151
Sep 8, 2005 05:42 PM
civicuser
Feb 25, 2004 09:21 AM
