reset srs
There's a red SEARCH button you can use for future reference.
Search Results
Your search for reset srs returned 66 results.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
yep use the 2 wire MES connector under the driverside dash an follow the procedure
connect the jumper wire to both pins on the airbag service connector (the one that does not have wires plugged into it, under the steering wheel)
turn the ignition to on
the srs light will go on for 6 sec then go off
quickly disconnect one of the jumper wires within 4 sec
the light will come on again, reconnect the jumper within 4 sec
the light will come on again, disconnect the jumper
the light will blink 2 times and go off if you did it correctly
turn the ignition off wait 10 seconds before turning it back on again if you want
(It is also much easier if you have a real piece of wire, not a paper clip) </TD></TR></TABLE>
Search Results
thewrai6th
Jan 15, 2009 05:28 PM
