hondata s200 questions
Old Nov 14, 2008 | 08:18 PM
Gearhead559's Avatar
Default hondata s200 questions
ok i got a p06 ecu with hondata s200...i'd like to use the hondata setup on a obd1 vtec ecu(gsr or the like) can i use this unit? or am i better off selling this unit and getting a different setup?
thank the gearhead
Old Nov 15, 2008 | 10:26 PM
ALLMOTOR18's Avatar
Default Re: hondata s200 questions (Gearhead559)
a P06 ECU can be used with Hondata without problems...
Old Nov 16, 2008 | 04:51 AM
xenocron's Avatar
thank the gearhead
If you are bringing it to a tuner, yes, you are good to go.
If you want to tune yourself, you need the ROM Editor 4 Software and Cable with the S200. If this is the case, I would recommend taking advantage of their trade in program.
http://hondata.com/v3upgrades.html
Old Nov 16, 2008 | 07:11 AM
Default Re: hondata s200 questions (xenocron)
i dont want to use the p06 i want to use the hondata on a different ecu!
Old Nov 16, 2008 | 07:34 AM
NJIN BUILDR's Avatar
You can use the s200 on other obd1 ecu's.You can also use a non-vtec ecu (like the po6) on a vtec engine by having the vtec circuitry added to the ecu.
silvercivic_ex-t
Mar 8, 2005 06:08 PM
Hoodwinked
Jan 5, 2005 01:11 PM
22boost
Nov 11, 2004 01:29 PM
aziz93
Aug 16, 2004 08:29 AM
