stereo
90 crx. i tried to pull the front speaker cover off the door by taking out the 2 screws i saw but cover is tight. does this cover have more than 2 screws? does the cover snap on? whats up? i dont want to force it if theres more.
There are 4 plastic clips that are molded into the grill cover, two on top and two on bottom, you are smart not to pull too hard. Take a thin tool (a butter knife works) and gently pry up between the plastic grill and vinyl door panel, they are about 1 inch in from the edges, pull grill gently while applying slight pressure up on the tabs one at a time.
Good luck, and remember.......plastic always bends before it breaks
Kirk R
Kirk R
