rims!!!
Old Nov 14, 2008 | 01:14 PM
jyracer's Avatar
Default rims!!!
i have these rims and im tryin to take off the blck paint that the previous owner put on them. im pretty sure theyre powder coated but not sure. they paint peals off like its vinyl but its tough as hell to get off. i sprayed a paint remover on it and a whole can didnt even get all of the paint off 1 rim. if any1 knows a trick plz let me kno
Old Nov 14, 2008 | 01:36 PM
Prudz_lude's Avatar
Default Re: rims!!! (jyracer)
they are most likely powdercoated. You need to get a sandblaster and sandblast them or get someone too do that for you. It will damage any polished lip that it may have but that can be fixed easily with high grit sandpaper and some mothers aluminum mag polish.
Old Nov 14, 2008 | 01:38 PM
jyracer's Avatar
Default Re: rims!!! (Prudz_lude)
well i got a pad that u put on a drill its rubber with little rubber brushes on it. but it took off the finish that was on it.
Old Nov 14, 2008 | 02:01 PM
twiztid00002's Avatar
spray aircraft stripper all over it then wait like 30 min, wire brush it all off, then sand
Old Nov 14, 2008 | 02:13 PM
jyracer's Avatar
Default Re: rims!!! (twiztid00002)
i sprayed that stuff and used a whole can on 1 rim and didnt completely take it off
Old Nov 14, 2008 | 02:18 PM
it might leave a little on but the take a wire wheel to it
jyracer's Avatar
ok man thnx
ITR0952
Mar 2, 2005 02:40 PM
Kyles ej1
Sep 29, 2004 05:55 PM
EJ1_519
May 7, 2004 11:49 AM
GOTNOS
Nov 2, 2003 03:10 PM
PoWeRBaN_PaNdA
Apr 30, 2002 11:01 PM
