Upgrading from 10.2 inch rotors
Old Nov 14, 2008 | 12:51 PM
ketchup's Avatar
Default Upgrading from 10.2 inch rotors
Currently I have the 91 EX sedan knuckles on my 91 CRX HF (rear disc brakes 40/40 prop valve) and I wanted to furhter better the braking ability. I was looking at a set of wilwood big brake kits (4 piston) and was wondering if I should go with the kit for the 91 EX sedan knuckles or should I revert back to CRX SI knuckles and bolt on the wilwood kit for those?
The kit for the EX has 12.19" rotors and the CRX kit would have 11" rotors. Another factor I want to consider is wheelsize. I currently have 17's but also am considering going back to something more effective like 15's. The kit for the CRX should clear 15's but the EX kit would require 17's.
I figure the big brake kit is the way to go, better braking AND weight loss!
your input is appreciated
Old Nov 14, 2008 | 01:27 PM
BigDare23's Avatar
If you're planning on downgrading to 15in rims, you just answered your own question.
Old Nov 14, 2008 | 01:45 PM
ketchup's Avatar
Default Re: (BigDare23)
I guess so.
Everyone loves 15's on their EF's, I'll just have to see what the fuss is all about.
Old Nov 14, 2008 | 01:51 PM
CRX Toad's Avatar
Default Re: Upgrading from 10.2 inch rotors (ketchup)
11.1" rotors will be plenty. That is what I run out on the track (road racing, closed circut) with 15's. 17's make a CRX ride like a hay wagon, IMO.
17's ----> 15's = upgrade
Old Nov 14, 2008 | 01:55 PM
redef90si's Avatar
Default Re: Upgrading from 10.2 inch rotors (CRX Toad)
15's with 11 inch rotors will be plenty enough
Old Nov 14, 2008 | 02:55 PM
ketchup's Avatar
Default Re: Upgrading from 10.2 inch rotors (redef90si)
Good thing EF knuckles are CHEAP!! I'll be sure to get the SI knuckles.
Thanks!
taggart_lumpy
Mar 30, 2011 09:01 AM
Red_ED8
Aug 8, 2008 04:23 PM
EXEGCoupe93
Aug 6, 2007 04:31 AM
ex voto
20
May 12, 2005 03:18 PM
advanracing62
Aug 28, 2002 06:46 PM
