1990 integra numerous electrical issues.
just picked up a DA yesterday like my old one. For some reason, the tach and temperature guage both do not work. Im pretty sure the fuel guage does not either. Also, the red brake light does not work when the parking brake is engaged, plus im almost positive my ABS light does not work either because one of the wheel sensors has a bolt missing and was turned enough where it wasnt even facing the excitor ring on the CV shaft, which should trip an ABS code. The dome light or chime for when you leave the headlights on does not come on either. Is there a specific area i should start looking? or am i stuck getting some wiring diagrams and tracing wires and components?
Start with checking the grounds in and around the drivers side dash; including behind the cluster, and the one behind the kickpanel.
