91 Accord needs swap help
Old Jul 31, 2002 | 09:26 AM
accordh22's Avatar
Default 91 Accord needs swap help
I have a 91 accord dx. I need to know what you have to do to switch it over to obd1. H22a.org doesnt tell you how cause they did a 92(obd1). Any help would be greatly appreciated.
Old Jul 31, 2002 | 09:33 AM
Accord94DX's Avatar
Default Re: 91 Accord needs swap help (accordh22)
you are obd1. anything pre-96 is obd1.
Old Jul 31, 2002 | 11:45 AM
accordh22's Avatar
Default Re: 91 Accord needs swap help (Accord94DX)
nope sorry evrything from 92-95 is obd1 .
Old Jul 31, 2002 | 06:07 PM
93acclude's Avatar
Your best bet is to find a 93 to 95 prelude si VTEC ecu. If you can get a copy of the electrical schematics for both your car and whatever car you get the ecu from you can make the nessecary changes to the wiring in the ecu connectors. That is what I did for my swap. Your 91 is obd1. Before I got my vtec ecu, I was running a 90 accord ecu with a vtec controller with no major problems.
[Modified by 93acclude, 3:11 AM 8/1/2002]
Old Jul 31, 2002 | 06:15 PM
H23 Power's Avatar
Default Re: 91 Accord needs swap help (93acclude)
the ecu is plug and play with the 91 harness...even tho the car wasn't obd1 everything still plugs up...91 and 92 cars are basically identical
Old Jul 31, 2002 | 10:54 PM
accordh22's Avatar
Default Re: 91 Accord needs swap help (01GSR)
Thanks for the help!! I just wanted to be sure before I jump on in. Isn't there only 4 wires that need connected? What do I have to do about the engine mount on tranny? I've heard to shave it a little , is this true?Thanks again guys!!
jmarquardt0221
Aug 26, 2012 06:03 PM
douspray
Mar 9, 2006 08:37 AM
91H22Accord
Jan 19, 2005 07:42 AM
accordh22
Jul 29, 2002 01:44 PM
