Need help...my gsr is vibrating when i start it up then turns off...
I started up my car 2day and the motor started idling wierd...it was shaking n then it turned off...i turned it back on and it kept doin it but when i gave it gas it wouldnt accelerate steady as it should.....the motor was shaking while i accelerated
Have you done anything to the vehicle recently. It sounds like it may be ignition related. Possibly leaking tube seals. Pull your wires and plugs. Check on there condition and see if you are having a misfire of some sort. Any cel codes?
thanx for the help guys but i figured out wat it was....my motor is supercharged and i had less than 1/4 gas so thats y it was doin it....since my fuel pump is high perfprmance it requires more gas than usual
jdm91integ
Jun 27, 2014 03:00 PM
Neptronix
11
Sep 1, 2008 12:49 PM
vdawg559
12
May 15, 2007 02:15 PM
DC2point0
13
Jul 24, 2005 06:02 PM
