have a problem going forward
alright where do i start. when i release my clutch my car would go forward then my relay would start clicking and it would die on me. when i put it in reverse and do the same thing it is fine. any pointers of where i should start?
before getting a new relay check all your grounds and make sure they're connected and tight. i had this similar problem (the one on the thermostat housing) and thought it was my main relay, it was causing it to click and the car would die or not start at all.
i had checked all my grounds and they are all connected tight. and i have 1 other main relay from the junk yard and a new one is like 180. don't have that much money. i will be ripping out my wires again today incase it got pinched somewhere. if it's not the negative it's def the main relay? guess i'm gonna have to dish out the money if it's not my negative. thanks guys i really appreciate it. it's hard to think straight when your all fustrated
nismogrendel
Apr 24, 2010 01:43 AM
silentblackhat
Jun 10, 2005 07:55 PM
