tire size
my stock size rsx tire is 205/55/16 i'm getting ready to put winter tires on,dont want to spend alot cause were gonna drive the integra the most over the winter,i can get used tires for cheap but there 225/60/16 will these fit without rubbing or am i gonna run into issues?
no your fine. most run 225 width with aftermarket wheels lowered and dont rub. the only concern would be if they would fit on the wheel. What width is the wheel? if it is at least 6.5 you should be fine.
http://www.wheelweights.net/
has a lot of wheel specs on this site. The 02-04 is 16X6.5
but wait, you are saying 05 that is a 17 in wheel. And also remember that in winter the narrower the tire the better. Should go with 205 width or even 195 and you can get some blizzacks from tirerack for a decent price.
prose
prose
This isn't comparable if your offset is different than stock. What's your offset?
if you are dropped really low then these will rub. Not only is the tire height higher but the tire is wider on a narrow rim which will create a ballooning factor which will increase tire height.
These tires aren't wide enough to cause a problem, its the height I would worry about personally.
I run a 18x7.5" wheel +43mm offset with a Nitto Invo 225/40/18 on my car but I am about to switch to an 18x8.5" wheel with a 255/35/18 on it and I don't expect any clearance issues but I am also dropped pretty low, lol
205/55/16 = 24.9" diameter
225/60/16 = 26.6" diameter
That's a difference of 1.7". That's huge. Speedo will be way off and you'll have to start to worry about the tires rubbing on stuff when you make sharp turns. It's sometimes not only about how wide the tire is, but how tall it is too.
That tire is way too big for an RSX.
http://www.miata.net/garage/tirecalc.html
prose
