wheel fitment question
im lookinginto getting an S2K by next month. and my question is about this wheel fitment. i was looking into doing 17x8.5 et 25 all around. am i looking into rolling the fenders at all or could i get away with it and still have room for lowering it around an inch or a lil more?
It will not work stock body. Sorry buddy
If you run these specs with a gap all around, it will throw an illusion that your wheels stick out more than normal. Up the offset to the 50's if you want to be safe. However, there is so much you can do to make things work, but I don't think it will be worth your headaches. Just a thought
et25 is way too low unless you want to hack up the body stretch the tires run -1515181 camber and have your car handle like poo.
Currently the most popular wheel size to run is 17/9 et45 and even with this you need to roll your fenders and depending how low you go youll need to flare the front and relocate bumper tab in rear.
Anyways get the car first b4 you start thinking about wheels!
eurocouture
11
May 3, 2006 08:29 AM
