Brake setup for summer
I plan to go with these brakes for the summer.
front brake setup
rear brake setup just need to source a rear disk swap.
The ss harlines seems to be too long. How do you route them??
front brake setup
Then just route them the same direction, just try to add slack in there where you can. Just make sure you have ample clearance, turn the wheel lock to lock and check it on the ground- you don't want that ***** rubbing on anything.
is integra ss lines longer than the civic ones? i have this feeling these are integra lines
CRX_1.8T
Oct 5, 2006 07:02 PM
