Suspension & Brakes Theory, alignment, spring rates....
I got some suspension goodies to put on my EK
Old Nov 14, 2008 | 03:25 AM
chickenwing's Avatar
Default I got some suspension goodies to put on my EK
the ASR subframe reinforcement, CTR swaybar, and Blox endlinks.
bought some new KYB bumpstomps, boots, top plates and poly bushings.
i got these front poly bushings only but nothing for the rear.
after complete installation I found it hard to set the Konis to a comfortable setting.
Either it was too hard with the car bobbing up and down or too soft.
How do you set it so it will not bob but still have some firmness for some spirited driving. Also I didn't think the H&R sport springs would lower the car that much
Old Nov 14, 2008 | 11:00 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
just turn it to full soft, then turn it back up 1/2 to 3/4 turn or so.
Old Nov 14, 2008 | 01:46 PM
katzenjammer84's Avatar
Nice choice with the Koni's.
Old Nov 14, 2008 | 04:01 PM
Default Re: (katzenjammer84)
I turned it to full soft and with one full turn it was still on the soft side. When i turn it to like 2 turns it was too stiff and bobbing on smooth pavement.
thanks it sure beats them cheap *** Ksports or DTM coilovers.
Old Nov 15, 2008 | 04:04 AM
Default Re: (chickenwing)
one of the bolt heads broke off for the rear LCA
This is very common especially with cars in montreal.
bolts gets rusted so so much that when you want to remove them. SNAP comes off the head of the damn bolt.
spin saw didn;t work well and didn't reach so I used these Lawson drill bits and must say they are amazing
vise grips and patience finally got these sucker out
endlinks installed
Old Nov 15, 2008 | 05:47 AM
hatchling37's Avatar
Holy rust bucket Batman. Should ride pretty nicely.
Nice custom wheel setup
Old Nov 15, 2008 | 01:35 PM
mnskateboarder's Avatar
looking good (the suspension parts)
Old Nov 15, 2008 | 03:28 PM
Doeboy's Avatar
man, throw some paint on that ****, rust is doing work on your car!
quality parts though!
Old Nov 16, 2008 | 06:08 AM
Default Re: (Doeboy)
Yeah rust is the only bad thing about living in the eastern canada.
I could find any honda hubcaps so I had some VW ones doing nothing.
These are much better than the K-sport and D2 stuff that blows all the time.
throwing paint on the rust will not prevent it but just temporarily cover it. It needs to be sanded and treated before paint.
Old Nov 16, 2008 | 02:08 PM
hayabusa160's Avatar
that bushing is on the wrong way. the taper side points up. on top and the bottom one points down.
the 2 wide ends sould be facing each other. and the narrow ends pointing opposite ends.
Old Nov 16, 2008 | 02:34 PM
Default Re: (hayabusa160)
good eye. I was just putting the parts together so I won't loose them. lol!!!
Old Nov 16, 2008 | 02:37 PM
ok as long as you know haha
Old Nov 18, 2008 | 09:16 AM
EK_B's Avatar
Yeah, the Sport springs lower more than stated. Your's look a little darker than mine which is like bluish-black.
Old Nov 19, 2008 | 03:26 AM
If I known it lower more than stated I would have kept the OEM springs and not spend the extra $$$.
The rear wheels are bowed out which i didn't like once the car was lowered.
Old Nov 19, 2008 | 04:32 AM
DrSeuss's Avatar
I believe the upper "cupped" washer on your front struts is on upside down. The "cup" should be pointed up not down. I don't think it will really hurt anything though. It'll just cut into the bushing a bit.
Old Nov 21, 2008 | 06:01 AM
yeah you got it
Old Nov 21, 2008 | 02:34 PM
TotalBalance's Avatar
Just letting you know that the lower tie bar you have put with ASR is useless. ASR itself serve as tiebar at the same time they reinforce the subframe.
Anyway! Great setup nonetheless. It is just sad there are so many rusts.
Old Jan 19, 2009 | 12:14 PM
jdmrida's Avatar
Default Re: I got some suspension goodies to put on my EK
do you mind if i ask how much did you spend for all these goodies? (need some for my ek)
flushek
Apr 29, 2011 08:00 PM
MORENO67
Feb 7, 2008 08:02 AM
Kafelatte
Mar 30, 2007 06:40 AM
enigma94
Jul 16, 2006 09:07 PM
chameleon
Oct 1, 2003 09:59 AM
