my engine shuts off and turns back on again while driving help!
Old Nov 13, 2008 | 09:12 PM
hondabeater's Avatar
Default my engine shuts off and turns back on again while driving help!
while im driving during highway speed my engine would shut off by itself and turn back on instantly....very scary. i went to the dealer today to see if it was the recall on the electrical switch but their computer already shows it's already been replaced. could it be the main efi relay? any help is appreciated thanks!
is this the part?
http://www.autopartswarehouse.....html
Old Nov 14, 2008 | 02:28 AM
P_Adams's Avatar
Default Re: my engine shuts off and turns back on again while driving help! (hondabeater)
Quick rule of thumb:
If you loose everything (Lights, Instruments etc) it could be (once again) the electrical portion of the switch.
If it just quits but everything else works, then we have to start looking elsewhere.
Does this car restart without problems, or do you have to futz with it?
Oh, by the way... Model and year please.
P
Old Nov 14, 2008 | 07:58 AM
Mr Yamada's Avatar
The warranty/recall replacement of the original switch doesn't have to mean that Honda installed a BETTER part.
The replacements were the exact same unit that was going bad in the first place.
Good Move Honda !!
Old Nov 14, 2008 | 08:25 AM
Default Re: my engine shuts off and turns back on again while driving help! (P_Adams)
its a 1998 accord 4dr dx
i didnt have to touch anything when the engine started again. i was driving highway speed and then all of a sudden the engine went out, rpm and temp gauge went to zero , but headlights and radio were still working. the key indicator started blinking but the car suddenly started again.
also a few months ago i had trouble starting the car in the mornings...it would just crank forever...so i just waited a few minutes and then the car would start
Old Aug 30, 2009 | 09:39 AM
ckabee1's Avatar
Was this issue resolved?
My 94 accord ex m/t has started doing this. While driving, it would just cut off. Once, it restarted itself. The other 3 times, I had to put in the clutch and crank. It started back w/o issue.
This morning after sitting all night, it had trouble cranking. Battery and alternator are new, no loose wires. I am wondering if it's the EFI relay.
Main relay issues seems to be hot start related. I have not had that issue.
Thank you in advance.
Chris
Hmm dumb question alert! Are the "main relay" and "EFI main relay" the same thing?
Old Aug 30, 2009 | 09:59 AM
ckabee1's Avatar
further searching suggested it could be the ignition switch.
I found this page http://techauto.awardspace.com/ignit...ch.html#Repair
Once I can check into this further, I will report back my findings.
If any of you have any other suggestions, I'm listening (In my best Frasier voice)
Old Aug 30, 2009 | 11:06 AM
P_Adams's Avatar
Chris
Chris:
... well, at least we have evidence that the search function works. You did find this thread from last year
Anyway, what do you mean by "trouble cranking"?
Slow cranking?
Extended cranking?
Crank / no start?
P
Old Aug 30, 2009 | 11:38 AM
ckabee1's Avatar
Hey,
it will begin the crank cycle and then it's dead; kind of like what happended while I was driving - suddenly nothing (like something was unplugged).
Old Aug 30, 2009 | 11:46 AM
P_Adams's Avatar
Hey,
I would definitely suspect the ignition switch.
It is serviced separately. It is not required that you replace the steering lock that it's mounted to. It is (however) retained by two (2) specialty screws (retainers) which are required to remount the new switch. (you have to drill out the old screws to remove the crapped out old switch)
P
Old Aug 30, 2009 | 04:10 PM
Targa250R's Avatar
be professional
Two separate problems.
That's caused by a bad ignition switch contact assembly.
Even if it was already replaced once by Honda under the recall, it can fail again. The only difference is that Honda doesn't cover it the second time, so you'll be paying.
That's caused by a bad main fuel injection relay.
Common problem on all fuel injected Hondas, and a very easy fix for '98-02 Accords.
Old Aug 30, 2009 | 05:41 PM
phootbag's Avatar
I've replaced Main relays to fix stalling issues. I've also replaced ignition switches as well. Both are common on your car. Also, my dealer is replacing recalled switches that have already been done at no charge. Yours might too...
Old Aug 31, 2009 | 03:03 PM
ckabee1's Avatar
I removed the ignition switch. I'm not sure if this is the cause but there are several spots on the contact area that's worn through the silver into the copper. I snapped a photo. You can see the copper areas on the larger silver things.
Does this look to be the cause of my intermitent stalls/no start conditions? I am replacing the switch anyway, just want to confirm the issue is fixed before I stall on a train track or something.
TIA
Old Aug 31, 2009 | 03:58 PM
Sketch o5's Avatar
it all sounds exactly like what happened to my 99 with its ignition switch. it was also done before and i ended up doing it again. the corrosion on the prongs is what causes it, so yea, that was most likely your problem.
Old Sep 7, 2009 | 04:00 PM
ckabee1's Avatar
Well, I bought a replacement switch from Autozone for $55. Getting to the switch just involved taking off a couple of covers. I tried to change the switch without taking the ignition assy off, but that was not going to happen.
I was able to remove the bracket bolts without drilling them. With a punch and hammer, I tapped them CC until they came out. The assy dropped off into my hand and I was back in business.
It's been two days and no more cut-outs. Thanks for all the advice and hope this info is useful to others.
Siabraham1990
Apr 17, 2019 04:37 AM
ELFviper
Dec 21, 2011 05:44 PM
nowind
Oct 22, 2006 10:17 AM
cb1999nj
Dec 11, 2005 02:26 PM
kamdog
Acura TL, RL & ZDX
Dec 17, 2003 11:38 AM
