Car won't start, please help
So i was driving today and my car just shuts off on me. Im not sure what the problem is but maybe i can get some help. I checked all the grounds and the battery is still good.
The first video is of the outside/engine bay
The second video is of a sound that i think may be the main relay? but its a clicking sound, you'll hear it
Thanks in advance!
Modified by krazyhmongboi at 6:25 PM 11/14/2008
Thanks in advance!
My car did the same thing (d15 motor) the coil went out when i was driving, Make sure you have spark, also make sure the timeing belt is good and didn't jump
Good Luck man
Good Luck man
the belt still seems tight from what i can see(taking off valve cover)
are the cams suppose to be the same? (pointed in same direction)
Modified by krazyhmongboi at 10:26 PM 11/13/2008
Originally Posted by subway
Maybe if you threaten to smash it with a hammer, it'll get scared and start working again.
like what was mentioned check for spark cause i had couple friends whos car died while driving and it all turned out to be the distributor not producing spark..good luck
Bobby if you need a relay I have a brand new one you can test with. (I'm not sure if the teg and civics are the same.) I've still have a problem with my car dying too. If I push it hard then come to a stop for ~10 secs, the car just dies. But it will start back up, really weird. Is that how yours is?
THE TIMING BELT IS BROKEN!!! have someone crank the car with the valve cover on and see if the rocker arms are moving,,, or cam for that matter...... you probably stripped the belt at the crank which is why it looks tight at the cams....
def check that belt out it looks hella tight and then make sure your getting spark i had a friend who had a prob with keeping the rotors in place and they would just come loose and not start..
Yeah, I'd check the belt, but I'd also see if its getting spark. I am almost betting its a main rely problem though, from the click inside the cabin. Only I dont think it'd sound like that, mostly just an actual clicking sound
Sounds like when my T-belt skipped a whole bunch of teeth and blew my freshly built 1mm os valved LS head
No start conditions check fuel, spark, and compression... in your case id check the belt for any sheered off teeth. If okay, reset timing and do a compression test to check for bent valves. Hope everythings alright man.
Originally Posted by wrenchez81
ill bet 100 dollars .... that he stripped teeth on his timing belt..... any takers pm me!!!
Dude... SHitty... NO compression for sure.
It has jumped time due to the belt being [freak]ed (not neccessarily broke) from the looks of it. The cam gear (intake)) is WAYYYYY out.
Regardless it DID jump time..... as long as you didnt while beating on it..., [freak] it, put a new belt on it line em up and if there are no dropped valves or anything obvious.. Do a compression check. If all seems well, id rock it...
If it were mine id take the head off and check the head/valves/pistons.
Pistons for evidence of valve contact, valves for the same, and have the head pressure checked (or you could do the poormans by filling the ports with rubbing alcohol and see if they leak.
TJ: yeap i hear the fuel pump priming..i'll pm you if i need that main relay .thanks!!
how do i go about checking the timing belt? i was just think'n about taking off the vc then the plactic cover (top portion)..you think that'll do?
i talked to stefan at advancestreetperformance (my mechanic) and he said he'll be at my house when he can
i wasnt beating on it at time of happening..i was just cruising doing about 35 then the car just just turned off ( i saw the oil and battery light lit) then pulled over
your timing belt is stripped
look at your cam gears!!!
your intake cam is a complete 180 off compared to the exhaust cam
no need to do anything else to find a problem
i see it clear as day in the pic
hope you didn't bend any valves!!!
