** D,B,K & S2K PARTS ** ALL MUST GO...
Old Nov 13, 2008 | 05:15 PM
DIFFUT'S INC.'s Avatar
Default ** D,B,K & S2K PARTS ** ALL MUST GO...
D series
95 civic valve cover $25
96 civic dx p2e $50
95 civic engine bay fuse box $25
B series
Type r cam caps with cam caps rails $65
type r oil cooler with center bolt $65
Type R head Bolts $25
B16 crankshaft $100
b16/ls oil pan $50
haft shaft m2m ends $50
Crankshaft pulley$ 40
b16 camshafts $50
gsr camshaft $65
k20
type s cooler with center bolt $65
type s intake vtc and ex gear $100
type s crankshaft timing gear $40
type s top timing chain plate $15
type s timming chain tensioner $50
type s oil pump chain $20
type s thermostat housing with lines $50
k24
k24a4 piston and rods $100
k24 water pump and belt tensioner assy $100
k24 fuel injectors $80
k24 thottle bodies $65
k24 thermostat housing with lines $50
k24 crank pulley$ 50
k24 timing chain $40
k24 crankshaft timing gear $40
s2000
s2000 cluster with plugs $225
ALL PARTS ARE NEG GUYS
THANK YOU
Old Nov 13, 2008 | 07:20 PM
Default Re: ** D,B,K & S2K PARTS ** ALL MUST GO... (DIFFUT'S INC.)
anyone ?
Old Nov 14, 2008 | 08:23 PM
bump bump
Old Nov 15, 2008 | 09:07 PM
to the top
Old Dec 8, 2008 | 10:34 AM
To the top
hybrid1990crx
Jul 22, 2010 12:54 PM
crvek9
Mid-Atlantic (Sales)
16
Feb 22, 2010 11:05 PM
DIFFUT'S INC.
Oct 23, 2008 08:25 PM
vtecman
Jun 24, 2004 08:35 PM
