b16a using a obd1 intake manifold
OK, car is a obd0 with jdm b16a. Its going to be running a JDM obd1 p30 manifold.
I see there is no FITV on the p30 manifold like the JDM b16a has.
So which throttle body has the FITV on it?
I am pretty sure its an obd1 so can i use the obd1 map on the throttle body?
Do i have to repin the connector or is it plug and play?
you dont have to run a fitv on it but yea you can use a obd1 throttle body and if the car is dx then yea you do have to repin it but if its a si then no? well i hope this helped you out some good luck with that
OK, first.. i need to run a FITV.
i also seen that JDM p30 manifolds don't have a FITV but their throttle body's do.
So my only question is should i run the Map on the obd1 throttle bosy or keep the firewall map?
I wanted to know if the pinouts are the same?
hatcht9x
Jul 29, 2009 11:13 PM
JibOnALib
Sep 14, 2005 09:47 PM
