i need your help!! alternator, ignition switch?
whats up guys well my 91 civic 4dr with a b16 swap its been sitting for a few months now because i can't figure out this problem and it has me stumped! well i've been having a problem with my car shutting off while im driving and not turning on...and i mean like crusing down the highway like at 50 mph then all of a sudden boom no power, engine is shut off, and none of my electrical is working. well i thought it must be a short so i go through everything and i dont fix the problem...then i took the alternator out and had it tested and they said it was good! my pops tells me that alternators do actually do that but i was thinking i should still have some sort of power in the car. i checked all my grounds and i've been thinking it might be my ignition switch but im not sure....so i was hoping you guys could steer me in the right direction.
Now I'm confused...
Are you getting any codes?
Now that I think about it... does it have an alarm? If so, how is it wired??
The no power thing makes me wonder. I noticed on the black '90 Si I just purchased it has a similar issue that has shown it's face twice now, but only for a split second...
You said it had a new main relay, but what about all of the fuses?
Installing an engine at 4:00am tells me you’re wrong - I forgot the ground, but still had power - but not a bad place to start looking...
If I understand the problem you’re losing all power???
yea man im losing all power! and i just ordered a new alternator and starter i ordered the starter because i've needed one but if its the ignition switch also i'll order one to and get it all done at once! and yea it does have an alarm
Siabraham1990
Apr 17, 2019 04:37 AM
