oil coming from head gasket???
Old Nov 13, 2008 | 10:00 AM
91sityguy's Avatar
Default oil coming from head gasket???
so i just wiped down my tranny yesterday and this moring after driving my car i look and my tranny has oil on it again its coming from the headgasket i believe...what would cause this?
Old Nov 13, 2008 | 10:26 AM
jlicrx's Avatar
Default Re: oil coming from head gasket??? (91sityguy)
are you sure it is the head gasket? have you checked to see if it is coming from between the distributor and the head? the distributor could need a new O-ring - happens a lot
Old Nov 13, 2008 | 12:25 PM
fireant's Avatar
Default Re: oil coming from head gasket??? (jlicrx)
Try a new distributor o-ring from autozone or the stealership, and go ahead and supplement it with some permatex gray.
If you have a vtec head, its also common for the solenoid to leak.
Old Nov 13, 2008 | 02:00 PM
alscrx's Avatar
Default Re: oil coming from head gasket??? (fireant)
what motor do you have??
Old Nov 13, 2008 | 07:45 PM
91sityguy's Avatar
i have the the mini me d15 block with d16 head it looks like its leaking right where the head blots to the block i didnt check the dist. but there is jb weld on the thermostat housing hahah
pooRmansss
Feb 19, 2009 03:24 PM
hatchback_al
Apr 11, 2004 06:43 AM
COREY ITR#625
10
Oct 21, 2002 07:21 PM
InfamousRS
Jun 2, 2002 08:21 AM
D1ANCER
Mar 18, 2002 11:28 PM
