Suspension & Brakes Theory, alignment, spring rates....
Suspension issue? Car bottoms alot.
Old Nov 13, 2008 | 09:05 AM
jay24k's Avatar
Default Suspension issue? Car bottoms alot.
Last past 6 months, I bottom out alot. My front end hits alot on slight incline changes. If I go over a speed bump, I can hear it sometimes hit the middle on the way down. When I turn corners if someone is in my car, I can hear it grind sometimes. Even when I hit a bump it does that. This never used to happen.
I was going to upgrade to Koni/GC, however when I bought my car, it was a year old in 2001. Apparently the guy upgraded the shocks already to Koni Yellows with Eibach springs. (Glad the dealership never noticed cause I bought it at a steal). I never took my tires off till this weekend and noticed this. Talk about a bonus.
So any ideas what I should look for? If I push the car down, it does not bounce so I'm assuming struts are good. However I do hear a squeaky spring sound. Is it possible the springs are sagging?
I have about a 1.5 finger room from the top of the tires. I swear it used to be 2 but I could be wrong. My tires are 205/45/17 or 205/40/17. I can't recall off the top of my head. I think they are 45 though.
Any suggestions would be greatly appreciated. I have my car tore apart for a timing belt install so perfect opportunity to fix it.
Thanks
Old Nov 13, 2008 | 10:30 AM
Tyson's Avatar
Default Re: Suspension issue? Car bottoms alot. (jay24k)
from what i understand, suspension squeeks can be dried out balljoints, in need to replacement. check the balljoint boots.
Old Nov 13, 2008 | 06:55 PM
jay24k's Avatar
Default Re: Suspension issue? Car bottoms alot. (Tyson)
I'm not an expert by any means. Are you referring to the joints of the CV joints on the axle? If so, yes the inner one is torn and I'm replacing the whole axle this weekend. That wouldn't affect the bottoming out issue though.
Old Nov 14, 2008 | 09:54 AM
Tyson's Avatar
no, i mean the balljoints.
and im only talking about the squeeks.
mrdeadman
May 20, 2013 08:12 PM
Ladiesx3Me
Suspension & Brakes
11
May 17, 2008 11:01 AM
ali7up
May 7, 2006 10:29 AM
EK k kay
Suspension & Brakes
Jul 19, 2005 05:07 AM
Ludefx
Feb 28, 2004 01:41 PM
