Rear disc rubs?
I just finished putting new pads and rotors on my 1998 Accord EX 4 cly with disc brakes all around.
When I rotate the right rear wheel the rotor seems to rub a little. You can spin the wheel by hand but I hear a little rubbing noise each time it comes around.
The other side does it too but the rub is more even sounding like it rubs a little bit but same amount through the whole rotation.
The right rear rotor seems to rub more in one spot when you rotate it not a constant rub like the left rear wheel.
Any suggestions?
Thx
Any suggestions?
Thx
hmm, did you have the rotors resurfaced? to run "true" again?
did u clean and relube the sliding caliper pins?
did u align the tabs on the brake pad to the caliper piston as stated in your other post?
sampson100
May 16, 2013 07:04 PM
accordingdone
Nov 30, 2010 05:57 AM
