Checking Motor Mounts
Old Nov 12, 2008 | 09:29 PM
kornerk12's Avatar
Default Checking Motor Mounts
What is the procedure to check these ? What are you looking for ? I remember seeing people torque the motor to check these, not sure exactly though.
Old Nov 12, 2008 | 11:39 PM
pimpdd101's Avatar
Default Re: Checking Motor Mounts (kornerk12)
pop the hood and hit the throttle and see if the engine jumps or moves around alot and see if theres cracking on the mounts
Old Nov 13, 2008 | 03:53 AM
P_Adams's Avatar
Of course excessive movement, but you can often get an eyeball on them as well. Look for indications of the rubber insulators separating from their fixture plate. In some extreme cases, the engine actually looked tilted in one direction.
Enlist a friend, agree on a "Beverage of Choice" and make a morning of it.
I would suggest waiting until AFTER you finish with the inspection before downing a cold one. You don't need things looking more tilted than they actually are.
P
Diversion
Aug 23, 2009 12:15 PM
IloveMyhoopty
Nov 8, 2008 03:43 PM
powderkey2
Oct 19, 2004 09:04 AM
NCSTIdriver
Sep 24, 2003 07:18 PM
VTi NA
Jan 28, 2002 02:30 PM
