lower seals
Old Nov 12, 2008 | 09:28 PM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
Default lower seals
I need help, my 94 lx is dumping oil in the sparks plug holes. i changed the upper seals with the valve cover gasket, that never solved the issue. Is there a write up on how to replace these seals # 19, engine is f22b2. If there is a link for a write up can somoneone post it, cause i can't find it in the search section.
Old Nov 13, 2008 | 04:21 AM
P_Adams's Avatar
Default Re: lower seals (kidcool1977)
I believe #19 represent the lower tube seals and they reside between the top of the cylinder head and under the upper Cam Retainers (Those things held down by 11,15).
I found this for you:
You'll need:
- in-lb torque wrench
- ft-lb torque wrench
- rubber hammer
- sockets/ratchet
- screwdriver
- blue high-temp RTV sealant or HondaBond
- plug tube seals, lower plug tube seals, valve cover gasket (AutoZone sells a set by FelPro for $16 that includes all the gaskets/seals you'll need)
- 4 new spark plugs (replace distributor cap/rotor and spark plug wires at your discretion)
Note: The camshaft bearing caps are removed together with the rocker arm assembly. To prevent the opposite end (transaxle end) of the camshaft from popping up (due to timing belt tension) after the assembly is removed, have another able body hold the opposite end of the camshaft down, then reinstall the bearing cap on that end to hold it in place until reassembly (if timing belt remains installed, but is easiest while changing timing belt when there no tension on the cam gear).
Step 1: Remove the valve cover
1- Remove spark plugs.
2- Remove the distributor cap and wires. Be sure to mark which wire goes where for correct intallation.
3- Mark and detach any hoses or wires from the throttle body or valve cover that will interfere with the removal of the valve cover.
4- Wipe off the valve cover the prevent dirt and debris from falling onto the exposed cylinder head or camshaft/valve train assembly.
5- Remove the valve cover (acorn) nuts.
6- Carefully lift off the valve cover and gasket. If the gasket is stuck to the cylinder head, tap it with a rubber mallet to break the seal. Do not pry between the cover and cylinder head or you'll damage the gasket mating surfaces.
Step 2: Position number one piston at Top Dead Center (TDC)
1- Remove the timing mark inspection plug.
2- Place the number one piston (closest to the drivebelt end of the engine) at Top Dead Center (TDC) on the compression stroke.
To do so, rotate the crankshaft pulley clockwise until the timing pointer on the block lines up with the TDC mark on the flywheel. The distributor rotor should be pointing toward the number one spark plug wire terminal on the distributor cap. If it isn't, rotate the engine one complete turn and realign the marks.
Step 3: Rocker arm removal and seal replacement
1- Have an assistant hold down the transaxle end of the camshaft, then loosen the camshaft bearing cap bolts 1/4 turn at at a time. Starting with the #3 cylinder loosen the two exhaust side camshaft bearing cap bolts. Loosen the bolt on the intake side of the assembly behind the spark plug tube. Repeat for #2 cylinder, #4, #1, and then loosen the cam bearing caps at the end #1 cylinder end of the head behind the cam gear. Finally loosen the 2 bolts at the #4 end that are closest to the distributor. DO NOT REMOVE THE BOLTS COMPLETELY FROM ROCKER ASSEMBLY.
2- Lift entire assembly off in one piece. If timing belt is in place, see note above.
3. Lower tube seals will be attached/stuck to the bottom of the rocker assembly. Remove pieces of lower plug tube seals (will probably be in severa pieces). Be sure to remove all remnants of old tube seals from rocker assembly.
4- Replace tube seals.
STEP 4: Rocker arm assembly reassembly
1- Replace rocker assembly.
2- In the reverse order of loosening, tighten rocker assembly bolts. The smaller 6.0 x 1.0 mm bolts need to be torqued to 108 in-lbs, and the larger 8.0 x 1.25mm bolts to 16 ft-lbs.
STEP 5: Adjust valves
1- With the engine still at TDC, the #1 cylinder valve adjustment can bve checked and adjusted. Start with the intake valve clearance. Insert a 0.010-in feeler gauge between the valve stem and rocker arm. Withdraw it, and you should feel a slight drag. If there's no drag or a heavy drag, loosen the adjuster nut and back off the adjuster screw. Carefully tighten the adjuster screw until you can feel a slight drag on the feeler gauge as you withdraw it.
2- Hold the adjuster screw with a screwdriver (to keep it from turning) and tighten the locknut. Recheck the clearance to make sure it hasn't changed. Repeat the procedure in this tep and the previous step on theother intake valve, then the two exhaust valves. For the exhaust valves, use a 0.012-in feeler gauge.
3- Rotate the crankshaft pulley 180-degrees counterclockwise (the cam pulley will turn 90-degrees) until the #3 cylinder is at TDC. With the #3 cylinder at TDC, the UP mark on the camshaft sprocket should be pointed at the exhaust side (nine O'clock position) and the distributor rotor should point at the #3 spark plug wire terminal. Check and adjust the #3 cylinder valves.
4- Rotate the crankshaft pulley 180-degrees counterclockwise until the #4 cylinder is at TDC. With the #4 cylinder at TDC, the UP mark on the camshaft sprocket should be pointed straight down, and the distributor rotor should point at the #4 spark plug wire terminal. Check and adjust the #4 cylinder valves.
5- Rotate the crankshaft pulley 180-degrees counterclockwise to bring the #2 cylinder to TDC. With the #2 cylinder at TDC, the UP mark on the camshaft sprocket should be pointed to the intake side (three O'clock position), and the distributor rotor should point at the #2 spark plug wire terminal. Check and adjust the #2 cylinder valves.
STEP 6: Put it all back together
1- Replace upper plug seals.
2- Replace valve cover gasket, and use HondaBond or high-temp blue RTV sealant to make sure there's no leaks. Let the RTV site for about 5 minutes to harden up before putting valve cover back on head. Torque the acorn nuts to 84 in-lbs. DO NOT overtighten these acorn nuts, as they are easy to split. If they break, you have a trip to the parts store in your immediate future in another vehicle.
3- Reconnect any hoses or wires from the throttle body or valve cover that previously disconnected.
4- Replace spark plugs with new NGK spark plugs - Reinstall distributor cap and plug wires.
I'm sure I've left some details out, but the bulk of the matter is here
P
Old Nov 13, 2008 | 09:14 PM
Community Builder
Default Re: lower seals (P_Adams)
thank you SIr ADAMS, i see that is a lot of work. Btw, do i need to re-adjust my valves after doing this job also you said to rotate the crank pulley clockwise, I think you mean COUNTERCLOCKWISE. correct or incorrect
Modified by kidcool1977 at 10:22 PM 11/13/2008
Old Nov 14, 2008 | 02:23 AM
P_Adams's Avatar
Furthur down in the text ... COUNTER clockwise
Refer Illustration:
It's the direction it rotates while running; and maintains the correct Cam / Crank relationship.
The first proceedure is to locate TDC only, not adjust the valves.
P
Old Aug 28, 2011 | 10:56 AM
newhondagirl's Avatar
ok so i just replaced the lower gaskets now its time to put it back together...i dont have the anearobic sealant that the haynes manual says to use...do i need it? I will probably be tearing into this again soon to replace head gasket...i also started this before reading enough and i did not move anything to TDC...is this bad? Also do i need to adjust the valves now or can i wait?? any help is appriciated greatly...ty
Old Aug 28, 2011 | 01:56 PM
Steve Z's Avatar
Well its only a problem if you didn't mark the relashionships of your cam to match up, and moved anything. The reason one starts from TDC is to maintain the proper cam timing. If you made a scratch mark to line up to and nothings been moved, you'll be fine. If not, yes you have a problem and you'll need to bring cyl 1 to TDC and realign your cam.
Old Aug 28, 2011 | 02:44 PM
GhostAccord's Avatar
Still not really a problem!
You will have to make sure that you bring your No.1 Cylinder to TDC. On the compression stroke the piston @ the top with crank pulley TDC mark lined up. Then once you have the cam and rocker assembly installed. Make sure to orient your cam so that it is also set to TDC before you put on the timing belt.
Yes you should adjust your valves, If you removed your rocker assembly you should have loosened all of your valve adjustment screws before you removed it. If you didn't you should loosen them before you put the rocker assembly back on. This will help keep you from possibly bending anything while you install the rocker arm assembly and tq it down. After it has been tq down you can go a head with the valve adjustment.
Old Aug 30, 2011 | 12:25 PM
thank you! got it all back together and all is well.
Old Sep 8, 2011 | 10:41 AM
hutcho3's Avatar
Anybody know where I can find these lower seals? I've tried a couple auto stores and nobody seems to know what I'm referring to and keep giving me the valve cover tube seals. What's the proper name for the lower seals?
thanks!
'91 CRX SI 1.6L
Old Sep 8, 2011 | 11:38 AM
They are known as O-rings, Honda part number 91301-PT0-003 Only found on the Non VTEC F22A & F22B motors. The VTEC F22B1 does not have the lower O-Rings.
I doubt many auto stores would sell them separately. Most aftermarket parts retailers would probably only sell them as part of a valve cover gasket set. A Honda dealership would be the best place to find the individual O-Rings. 91301-PT0-003 x 4.
zedjr
Jan 30, 2013 10:14 PM
Adam_F123
Apr 24, 2011 12:45 PM
teletekman
Mar 2, 2006 07:07 AM
loup05
Jan 28, 2006 05:30 PM
amir904
Aug 12, 2005 07:45 AM
