Harsh Shifts
Old Nov 12, 2008 | 09:25 PM
kornerk12's Avatar
Default Harsh Shifts
Well my 95 LX had about 70k on it when i did a trans flush. Prior to the trans flush it did shift hard and the fluid was burnt. I flushed it and it def helped with the shifting. Usually it feels fine on upshifts, if i sit at a slow speed or coast alittle and then hit the gas to accelerate it will downshift and it bangs pretty damm hard. It will also bang sometime when i put it in reverse. It did this before the flush also. When it was flushed, honda atf was not used. Im not sure what they put in there exactly. I believe it was a dexron III fluid i forget the brand. However is it worth the extra money putting honda atf in there ? Also what could be causing my harsh shifts ?
Old Nov 14, 2008 | 01:29 PM
cjmurillo's Avatar
is your tranny still full of fluid....and the honda tranny fluid helps in my opinion.....shifts a lot smoother
Old Nov 16, 2008 | 09:28 AM
kornerk12's Avatar
Default Re: (cjmurillo)
Yea dead on the full mark.
PA07
Transmission & Drivetrain
Oct 11, 2014 06:37 AM
globy123
Dec 17, 2006 07:20 PM
krazycivic4u
Jun 3, 2006 08:18 PM
integraboi1010
May 21, 2004 09:50 AM
Money Hou$e
Apr 24, 2002 04:46 PM
