Which car is my rear disc conversion from.
What's up HT. I dug out a rear disc conversion I bought about two and a half years ago. I was told it was from a DC integra. I have another trailing arm that I pulled from a 1995 integra myself and the two are actually different. Is there anyway for me to tell which car these rear disc came from? I don't wanna go through the mission of taking everything apart and finding out it doesn't fit. Any special markings or part numbers I can look for? Thanks alot.
Regardless of the arm, the hub should bolt up to the trailing arm you have in there right now. The hub is really all you need (aside from the calipers, anchors, rotors, and pads obviously). I believe it's a T55 torx bit you will need to remove the bolts.
wade
Suspension & Brakes
May 25, 2006 12:18 PM
