ls/vtec hp?
what hp to expect...
13:1comp pistions
ported gsr head
itr cams
eagle rods and bolts
18b1 block
itr valvetrain
hondata s300 ecu
10lbs flywheel
gsr trans lsd
310cc injectors
13:1comp pistions
ported gsr head
itr cams
18b1 block
itr valvetrain
hondata s300 ecu
10lbs flywheel
gsr trans lsd
310cc injectors
hmmm i'm guessing possibly 190-200. between there. maybe little more if a good *** tune. have you ever thought of using CTR cams instead? i believe they are much more aggressive than the ITR.
Check in the all motor forum they have builds and dynos that are about identical to yours. Welcome to H-T btw. Just use that big red search button at the top of the screen and you will most likely be able to answer all of your questions in the future.
HuckelberryT
May 7, 2015 04:03 AM
allmotor-teg
May 1, 2011 05:14 PM
DARKCYDE671
Nov 13, 2008 06:42 AM
