need help with a f22b DOHC v-tech
Old Nov 12, 2008 | 05:39 PM
true-elements's Avatar
Default need help with a f22b DOHC v-tech
i have a 92 accord lx 4 door with 5-speed and i plan to drop an accord ex. i need to know if i can use the same wiring harness, tranny p/s pump distributor etc. and also is there anything more iwill have to change or is this a direct bolt on..THANKS...
Old Nov 12, 2008 | 06:29 PM
hon2984's Avatar
Default Re: need help with a f22b DOHC v-tech (true-elements)
you need some help brother. F22B1 is not DOHC. H22A is DOHC VTEC.
Old Nov 12, 2008 | 07:03 PM
Merks's Avatar
Default Re: need help with a f22b DOHC v-tech (hon2984)
There is a F22B that is DOHC. If I am not mistaken it was found in 4th gen preludes or 3rd gen
Old Nov 12, 2008 | 07:20 PM
GhostAccord's Avatar
Default Re: need help with a f22b DOHC v-tech (Merks)
It was a JDM F22B DOHC Non-VTEC therefore it was not found in any USDM vehicles.
OP,
You need to do a bit more research into what engine it is that you are putting into your car. If it is the F22B1 from the 95-97 US Ex. Then you will require a VTEC ECU and the wire harness/or you could add the VTEC wires to your existing harness.
Old Nov 13, 2008 | 11:53 AM
Brad_and_the_acc's Avatar
V-TECH BEECHES
wOoT wOoT!!!
lol
CD7panda
Feb 5, 2016 08:20 PM
wardcrx
May 25, 2007 07:21 AM
he_man
Nov 19, 2004 08:29 AM
