Does a Skunk2 Dual Bend shifter fit in crx?
I bought a Skunk2 dual bend shifter and shift **** combo from a authorized dealer on ebay. The description said 88-00 civic and 90-01 integra. But when I received it the box says 92-00 civic and 94-01 integra. I checked the part number on Skunk2 but it gives no info as to what vehicles it fits. Will this still fit in my rex?
Thanx
Thanx
i put a stock gsr shifter in my sedan and i had to cut the part where the bolt goes through so it would fit in the d series linkage cause it was to wide,not sure if skunk2's would be the same or not but i think the bottom where it bolts on is wider for the b-series linkages.
Your all good. 88-91 always gets left out but it will fit just the same as 92-00.
