ECU for B16A?
Was wondering for a 92 CX which ECU can be used for a B16A swap. I know the Si-R II would be a choice but how about a 92-93 GS-R or any thing else OBDI. My friend just got the motor and was wanting a plug in ECU with minanimal wiring changes. Also which Distributor would be used for each ECU?
Trust me you don't want an P72 unless you are planning to getting a piggyback system like Hondata. It runs way tooo rich. I have this setup. Also you could use a LS distributor or GSR OBD I.
94-95 uses the same ECU plugs as the 92 Civic kewl didn't know because the tegs and civics alway cross up years. So just use the GS-R ECU and diz from either the LS/GS-R same year? By the way this is for a B16A3 from the 99-00 SI's so the Diz would bolt right up correct.
You can find chipped 92-95 ex-si ecu's on here all the time fairly reasonable. Also there are a couple of p30 ecu's but they are kinda pricey. Also you can use the obd1 pr3 ecu but it's kinda rare and just as much as a p30.
or if you cant afford it....a p30 works :/ Im selling one if interested, it was in a car accident that tweaked the casing, the ecu is still good, i can post pics....i took it apart and it has no internal damage, it would run well until you could afford a chipped p28. let me know :/
do not get the gsr ecu. i was using it for a while and it sux on a b16. the p30 is perfect because it was made for it. im using a 98 type-r right now and its alot better than the p30. wen i get my type-r cams in, everything will be A-OK. you might need type-r injectors too.
1phatsol
Dec 1, 2002 04:26 PM
