What is the difference between a GSR and Type R OEM clutch?
Old Jul 31, 2002 | 04:19 AM
DevinW's Avatar
Default What is the difference between a GSR and Type R OEM clutch?
Hi guys,
Just wondering what the differences were, if any.
Thanks for you help!
Old Jul 31, 2002 | 06:35 AM
legendboy's Avatar
Default Re: What is the difference between a GSR and Type R OEM clutch? (DevinW)
I just put a GSR clutch in my RS, I think its the same as ls/rs/gs with a bit more clamping power, Type-R clutch needs Type-R flywheel too I think. It is lighter and stronger than gsr.
Old Jul 31, 2002 | 07:08 AM
DevinW's Avatar
I'm getting a Type R flywheel...so should I go with a Type R clutch?
Old Jul 31, 2002 | 08:44 AM
owen_the_soyboy's Avatar
Default Re: What is the difference between a GSR and Type R OEM clutch? (legendboy)
ITR clutch is different from GSR and LS clutch. Stiffer springs in the pressure plate.
ITR flywheel is a few pounds lighter than GSR or LS flywheel.
ITR clutch does not need to be mated to an ITR specific flywheel.
-you can mix and match, its whatever you can afford really.
-if I had to buy a new flywheel I would buy an aftermarket 8 or 9 pounder, not a stock ITR flywheel.
hope that helps
Old Aug 1, 2002 | 05:14 AM
DevinW's Avatar
Default Re: What is the difference between a GSR and Type R OEM clutch? (owen_the_soyboy)
I'm getting the Type R flywheel for cheap...that's why I'm getting it!
h22_crx
Apr 9, 2006 07:56 AM
djecue
Dec 5, 2002 03:37 PM
VTECHEART
Aug 10, 2001 03:30 PM
