Crossmember going out?
Old Nov 12, 2008 | 01:55 PM
KhmerdudeSiR's Avatar
Default Crossmember going out?
Is that posssible? recently i been hearing clunking noise from the front when i take off or shift, the 2 front axles are brand new so i doubt it would be that, if anything, what else would it be? all i could think of is the xmember, Lmk what you guys think it is, i can give you more additional info if needed, thanks!
Old Nov 12, 2008 | 01:56 PM
stickyicky's Avatar
sounds like it could be the motor mounts
Old Nov 12, 2008 | 01:59 PM
StayKrafty's Avatar
I'm having the same problem, but my motor mounts are new.
Old Nov 12, 2008 | 02:15 PM
Default Re: (stickyicky)
Hmm il check that but when i was inspecting for the prob my motor was really stiff and it felt like my mounts were fine. But il double check, The sound is like some sort of clunk mixed with a pop, like a axle popping into place, haha its like a really bad case of dash hop except its something from the front suspension
Old Nov 12, 2008 | 02:42 PM
josh352727's Avatar
Default Re: (KhmerdudeSiR)
I got that same noise, since I don't daily drive the car I havent looked for the poblem yet. It is odd though. Goodluck and post the fix when you find it.
Old Nov 12, 2008 | 05:06 PM
sgallagher's Avatar
Default Re: (josh352727)
Check your front strut rod bushings, Lower & upper ball joints.
Make sure all your suspension is tight. When your axles were replaced something could have been left loose.
Old Nov 12, 2008 | 05:18 PM
ejLday's Avatar
Default Re: Crossmember going out? (KhmerdudeSiR)
does the car shake when you step on the gas? If so it could be your axles I had the same problem only one axle was bad
Old Nov 12, 2008 | 05:29 PM
teg_95's Avatar
Default Re: (sgallagher)
X2. had the same problem took the wheel of noticed i didnt have a ball join bushing=bad ball joint
Old Nov 12, 2008 | 05:48 PM
Everything is tright after i replaced the axles, it made the noise before i changed it also, but il check the rod bushings and ball joints
Old Nov 12, 2008 | 05:49 PM
Default Re: Crossmember going out? (ejLday)
Yea it does when i let off and then tap the gas again, but i just replaced the axles and both are brand new,
Old Nov 12, 2008 | 06:45 PM
IHEARTMYHONDA91's Avatar
maybe loose radius rods....
tie bars....
lol idk
Old Nov 13, 2008 | 09:15 AM
bsixteener's Avatar
Default Re: (IHEARTMYHONDA91)
This same problem just happened to some guy I know I chacked all his suspension and everything seemed to be cool until I checked his main nut that connects his axel to the hub and the IDIOT that had done his axels has left this loose so you might want to check that.
Old Nov 13, 2008 | 06:23 PM
90sedan's Avatar
Default Re: (bsixteener)
Basically look for anything loose on the front end. This could very easily be caused by a loose motor mount or a loose radius arm.
Just jack the front end up and start hunting.
grey_ghost
Jan 30, 2008 12:55 PM
russianswty
Jul 6, 2007 10:33 AM
SpeedMachine
Jan 27, 2005 09:38 AM
UnionCity LS
Jul 27, 2003 08:54 PM
MeanGreenEG9
Dec 16, 2002 07:20 AM
